Author Topic: XSD Generation  (Read 5332 times)
Ruslan
XSD Generation
« on: June 20, 2003, 06:07:10 am »
I want to generate XSD Schema from a model. I copied XSDDataTypes Package and  UML Profile for XML, but I can’t import XSDDataTypes Package.
In help I found:
“To import a package from XML
Select the package to import in the Browser
Right click and select the Import/Import menu option - Import From XML file”
I didn’t find this menu in browser.
saschwarz
Re: XSD Generation
« Reply #1 on: June 20, 2003, 07:56:52 am »
Hi
The way I did it was:
Go to Project Explorer
Right mouse on the View containing the data model in which you want to import the xml.
Select "Import/Export"
Select "Import package from XML file..."
Then browse to the XSDDataTypes package.
There is just a simple typo in the help..."Import/Export" in place of "Import/Import".
Hope this helps
Steve
Ruslan
Re: XSD Generation
« Reply #2 on: June 20, 2003, 08:00:54 am »
Thank you. I found.
Ruslan
