Author Topic: Using only SQL Server, not *.eap files?  (Read 2995 times)
stenio123
« on: July 04, 2003, 06:59:56 am »
Hello from Brazil!
I'm planning on using EA with SQLServer 2000. I already know how to transfer data between then. I would like to know if its possible to use only SQL Server as a data repository, with no further need to transfer data.
I searched the documentantion, and on SetUp_SQLServer.txt found the cryptic phrase :
Once the process completes, you will have upsized your model to SQL Server and can now open it from EA (see help file for details on connecting to a DBMS Model)
Does this mean that from now on I can use only SQL Server and forget *.eap files or do I still have to transfer data every time I make a change? I couldn't find any mention of this in EA's help.
Thank you in advance and congratulations for your great product!
hd
Re: Using only SQL Server, not *.eap files?
« Reply #1 on: July 06, 2003, 03:46:18 pm »
You can indeed continue to use just SQL Server as the repository. There is no need to revert to the EAP files. :)
