Author Topic: Exporting Use Case Documentation  (Read 3544 times)
cb
« on: August 02, 2003, 12:36:01 pm »
Is there a way to include screen shots as part of the documentation that is exported for use cases?  I have attached files to a use case by using the Files tab.  Is there a way to include the actual contents of the file in the RTF export, instead of the file name and location?
Thanks!
mbc
  • Embedded software developer
Re: Exporting Use Case Documentation
« Reply #1 on: August 04, 2003, 03:44:26 am »
You can include the screenshots in some diagrams. In the diagram, insert a boundary object. Right-click on the object and click "Choose associated image". You can then choose which image file should be displayed in place of the boundary object.
I hope this will be of help to you.
Mikkel
cb
« Reply #2 on: August 04, 2003, 02:56:55 pm »
Thanks!  That did help.  I can create a sub use case diagram under my use case and add boundary objects to it.  Setting the image property on these boundary objects does have the image show up in the RTF documentation.
Thank you!  :)
