Author Topic: Version 4.00 - Build 721 Released  (Read 20372 times)
sparks
« on: March 18, 2004, 03:23:46 am »
Release Notes for EA 4.00 Build 721
Fixed error that caused context menus on some elements to display incorrectly when Current Element toolbar visible and Fade menu style shosen
Fixed error with Activity and Action elements when wrapping long element names - name could overrun element boundary in some cases
Fixed foreign key association into column with a unique constraint.
Added "Action" support to the <Apply/> Element in the UML Profile XML.
Added check box on RTF document generator to allow exclusion of "Advanced Properties" - check box named "Extended Properties"
Space evenly - Vertical - problem corrected
Added check to "Move External" function on Element properties/Requirements tab. Checks for valid current record before allowing function to proceed
Corrected problem with diagram tab "Save All" function
Added check box to Swimlane dialog from diagrams - provides ability to suppress Classifier names when set
Fixed missing back slashes in file path when generating package DDL on a PostgreSQL reopository.
Modified display of Attribute and Operation "Alias" in diagrams to only show when Diagram Checkbox "Use Alias" checked.
Diagrams in "Diagram Only" report now supported by Name
Added ability to move elements in project browser directly under View nodes using drag and drop.
