Author Topic: Web application modeling with UML  (Read 3489 times)
petercch
« on: August 23, 2003, 11:56:16 pm »
For designing Object Oriented Software with UML, it' still OK for me.
But I'm going to develope a web site (e-learning web site) with Rational Unified Process and the design tools is UML.
So, how should I diagram it?
Should I assume each *.php as one class and do the rest like usual?
Since I'm using PHP 4 as the programming language and I didn't use class in it. I just code it as normal function. So I don't have any Object in my code. Therefore I'm confuse of using the Object Oriented design tool - UML for design the web site.
I already read the article of RUP from these URL:
Ten Essential of RUP
RUP Implementation Guide
If my question is too confuse or complex for explanation, can someone provide me links to website that related to it?
(other than http://www.rational.com)
If I can have a Table Of Content of any project that develope using RUP and UML, than it would be VERY much appreciated as Table Of Content usually would be a good guideline.
Thanks for helping.
Peter CCH
RUP and UML is a requirement.
I cannot change to use other design tool such as those old DFD and cannot use those old development methodology like SDLC.
kelly_sumrall
Re: Web application modeling with UML
« Reply #1 on: August 24, 2003, 06:13:28 am »
Peter,
There is a good paper that explains how to design a web app with uml by Jim Conallen at http://www.rational.com/media/uml/resources/documentation/27662_webapps.pdf.  He has also written a book called "Building Web Applications with UML" that may benifit you.
Kelly Sumrall
Even though curiosity killed the cat, it still had eight lives left.
