Author Topic: Quotation mark in template output (EA 3.6)  (Read 6540 times)
Spaider
« on: September 01, 2003, 08:02:52 am »
Now I'm studying code templates and faced with unexpected trouble:
How can I generate quotation marks in resulting code?
(e.g. for generating string parameters).
Most common escape sequences doesn't work. I've tried \", \034, \0x22, I've tried doubling quotation marks. No positive results :(
Thanks in advance!
Sam_Mancarella
Re: Quotation mark in template output (EA 3.6)
« Reply #1 on: September 01, 2003, 04:51:20 pm »
EA3.60 (635) currently does not allow escaping of the percent symbol (%), dollars symbol ($) or double-quote symbols ("). Presently, to escape a % or a $, it would have to be assigned to a variable as a string literal, viz:
$dollar_sign = "$"
$percent_sign = "%"
$something = $dollar_sign + "foobar" + $dollar_sign
This behaviour is described under "Planned Extensions" in the "Code Template Framework" section of EA's help.
To escape a double-quote in templates is somewhat different. You would have to output the double-quote as literal text.
For example - the Operation Body template in VBNet and Visual Basic has the following statement:
 %opName% = ""
Which assigns a return value of "" if the operation is a function and it is of String type.
To achieve a similar result for setting default parameter values (for example), you could use the following "Parameter" template in VB  and VBNet:
%PI=" "%
%paramDefault ? "Optional"%
%paramKind == "in" ? "ByVal" : ""%
%paramKind == "inout" ? "ByRef" : ""%
%paramKind == "out" ? "ByRef" : ""%
%paramName%
As
%PI=""%
%paramType%
%if paramType == "string" and paramDefault != ""%
="%paramDefault%"
%else%
%paramDefault ? "=" value%
%endIf%
NB: To use this template, you would have to ensure that your default string parameter value is saved without quotes.
Hope this helps.
Sam Mancarella
Sparx Systems
Spaider
« Reply #2 on: September 02, 2003, 02:03:22 am »
Hope this helps.
Unfortunately, it doesn't :(
I have slightly different situation. Here's an example: suppose, I want to notify that some property has changed. I had method NotifyPropertyChanged () for this. It takes one argument of type System.String (I'm writing in C#).  I.e. the code snippet for property setter will be something like:
public double Amount
  set
      m_Amount=value;
      NotifyPropertyChanged ("Abount");
How should I modify default template
$att=%opTag:"attribute_name"=="" ? "<unknown>" : value%
%if opTag:"writeonly" == ""%
$read="\tget{\n\t\treturn " + $att + ";\n\t}"
%endIf%
%if opTag:"readonly" == ""%
$write="\tset{\n\t\t" + $att + " = value;\n\t}"
%endIf%
to achive this?
PS Don't treat me lazy :) I've tried all variants I can imagine (not forgetting RTFM)
benc
« Reply #3 on: September 02, 2003, 05:21:16 pm »
Hi Spaider,
I think the problem stems from not  currently being able to use the quotes in variable definitions.
I may be misreading your intention here, but I think the following modifications to the default OperationBody template (with property stereotype) achieves what you are after.
1. Change the line:
to
$write="\tset{\n\t\t" + $att + " = value;"
2. Change the line that finally outputs $write. So:
$read
$write
becomes
$read
%if $write != ""%
$write
\t\tNotifyPropertyChanged("%opName%");\n\t}
%endIf%
3. Now when I generate the property I get:
public String Amount{
 get{
   return att;
 set{
   att = value;
   NotifyPropertyChanged("Amount");
Admittedly, this solution is far from elegant, because the quotation marks could not used as part of the first variable definition for $write.  We will be updating the template syntax ASAP to support use of the ", %, $, characters.  For the short term at least, this will probably take the form of special macros- something %qt%, %pc%, %dl%.  Then they can be mixed with variable references/definitions and literal text.
I hope this helps.  Let me know if I've misread the problem.
Regards
Ben
Spaider
« Reply #4 on: September 02, 2003, 10:12:11 pm »
Many thanks!
This time everything is OK.
benc
« Reply #5 on: September 04, 2003, 10:24:52 pm »
Hi Spaider,
As of build 638, you can use the %pc%, %dl% and %qt% macros to get %, $, " characters respectively.  You can use these with variable definitions or as a direct substitutions.  Should provide a neater solution for getting the quotation marks into your property bodies.
Ben
