Author Topic: Version Control - EAP File Question.  (Read 2960 times)
iran
« on: September 25, 2003, 10:40:51 am »
Is there a way to open the <Project Name>.EAP file in read-only mode and just check out and edit the individual xml package files?  This is much like Rational Rose does with its main MDL file and sub package CAT files.
--Iran.
CJ
Re: Version Control - EAP File Question.
« Reply #1 on: September 26, 2003, 04:50:25 am »
I think "Controlled Packages" would do the trick.
Cheers and best regards.
iran
« Reply #2 on: September 26, 2003, 07:08:02 am »
We have been doing that.  The issue we are having is that it seems like the EAP project file needs to be read/write so having it in source control and getting read-only copies has been workable, but annoying.   Team members copy the read-only version from their local repository to a working/temp directy and make it read/write. Team members checkout the "controlled package" when they want to edit it.  They checkout the EAP file when they want to add a new "controlled package" to it.
The database controlled eap file would be great, however it seems that there is a bug in EAP where the tree showing files/packages/etc. automatically collapses when you are working in it while connected to a database.  For instance, when you right-click on a package the tree collapses.
Any advice would be great. Submitting a bug report now  :-/
