Author Topic: RTF report with BPMN diagramm  (Read 3418 times)
maxim_caban
« on: March 22, 2007, 07:06:16 am »
Hi!
I use BPMN add-in but when i try to make rtf report (default setting) i dont see correct sequenceflow lines and gataways in the document.
But in html report everything ok.
Anybody can help me?
Maxim
Re: RTF report with BPMN diagramm
« Reply #1 on: March 22, 2007, 01:57:58 pm »
You haven't given much detail, but if your problem is what I think it might be then it was fixed in EA 6.5.804. From the release notes:
Resolved issue where default colors being rendered incorrectly for metafile output.
If upgrading to build 804 doesn't fix the problem, then please send a bug report to Sparx support, preferably attaching a cut-down EAP file, or an XMI file, or screen shots. If you can't upgrade to 804, try using bitmaps instead of metafiles in your RTF documentation.
Neil
« Last Edit: March 22, 2007, 01:58:53 pm by KP »
maxim_caban
« Reply #2 on: March 23, 2007, 12:57:51 am »
Thanks a lot! 804 version correct work with BPMN and RTF
