Author Topic: c# interface generation  (Read 2606 times)
Salty_Dog
« on: October 08, 2003, 06:21:35 am »
Hi Guys
I am using build 646. I no longer get the inappropriate public specifiers in the itnerface, however if I have an interface with some properties, and some operations, I get incorrect code in the class that realises the interface. The properties work :-
     int itestif.testprop1 {
           get{
                 return fred;
the insertion of the itestif before testprop1 obviates the need for the public modifier. I woulod have preferred public but that's ok
however the operation comes out :-
     void testop1(){
without either the public modifier or the itestif before testop1.
help
benc
Re: c# interface generation
« Reply #1 on: October 08, 2003, 04:57:18 pm »
Hi Salty_Dog,
This issue has been corrected and the fix will be in release 647.
(The fault was in the C# Operation Body templates- they were not omitting the curly braces.  So if you need this fixed immediately, you can override the default templates to check for and handle interface element types).
Ben
