Author Topic: Help!  (Read 3504 times)
MikeH
Help!
« on: October 23, 2003, 12:41:16 pm »
Hi, All,
I'm trying out EA, and comparing to other tools. It seems to me if I delete an entity from a disgram, it dispears (invisible) from diagram, but still there on the project view (if I create document, it's there). Is it possible to remove it while it is removed from the diagram?
Also, can you tell me your general experience using the tool (If you have used other tools, please compare.). I'm working on GUI and control code for embedded app. As of right now, I plan to use a UML case tool only for analysis, modeling, and documentation, not much of code generation. So the features and price of this tool attract me. Thanks for your help.
Mike Huang
GaryWong
Re: Help!
« Reply #1 on: October 23, 2003, 03:08:06 pm »
If it isn't on any diagrams but you see it in the Project Explorer then you should right-click the element (in the Project Explorer) and choose 'Delete ..' near the bottom.
Alternatively, if the element is highlighted on the Project Browser then you can simply hit Ctl+Delete.
Gary
