Author Topic: Empty DBMS Datatype listbox (eval)  (Read 3618 times)
bko0
  • www.oberholtzer .net
« on: August 16, 2003, 12:06:32 pm »
I'm running an evaluation copy of EA and want to play around with the DDL generation.  When I create a column, the Datatype listbox is empty.  My first assumption was that I needed to set the type of database server I'm using.  I've spent a little time looking through the online help but haven't found a way to set the DMBS type.  Am I missing something or is this feature not available in the trial version?
Thanks for any help you can give,
Brian
hd
Re: Empty DBMS Datatype listbox (eval)
« Reply #1 on: August 17, 2003, 03:28:55 pm »
Set the DBMS in the Table Properties... dialog. There is a drop down list 'Database' to select the target DBMS. :)
mbr
« Reply #2 on: November 10, 2003, 05:20:48 am »
Hi
I have the same problem. But there is no dbms drop down on the Table Detail Tab. There are only three buttoms:
Colums/Attributes
Operations
Generate DDL
What do I do?
