Author Topic: Checking for User Lock does not work  (Read 3280 times)
Kikai_no_Tenshi
« on: April 03, 2007, 02:57:21 am »
Hello!
I try to check if a package has an User Lock.
But I don't know which attribute of package it is (imho the user guide is not precise enough at this point)
I already tried:
package.IsProtected
package.IsControlled
package.IsVersionControlled
I tried to find out if a package is user locked with the following if-statements:
set o = app.repository.GetTreeSelectedObject
set p = app.repository.GetPackageByID (o.PackageID)
If p.IsProtected = True Then
   MsgBox "User Lock"
Else
   MsgBox "No User Lock"
End If
If p.IsControlled = True Then
   MsgBox "User Lock"
Else
End If
If p.IsVersionControlled = True Then
   MsgBox "User Lock"
Else
End If
I tried this with a package which has a User Lock and with a package which has no User Lock.
Both times I just got "No User Lock"-messages.
So how can I find out if a package has a User Lock or not?
I am running the new Build 805. Hope you can help  :-[
edit: I found out that it is working with elements.Locked, but not with packages and diagrams.
« Last Edit: April 03, 2007, 03:40:26 am by Kikai_no_Tenshi »
Re: Checking for User Lock does not work
« Reply #1 on: April 03, 2007, 01:01:14 pm »
As you've found, the user lock is a property of an element, so you'll need to use p.Element.Locked.
