Author Topic: Inner class in C++  (Read 3013 times)
billy_mumphry
Inner class in C++
« on: November 17, 2003, 03:52:39 pm »
I would like to generate, in C++, an inner struct (or simply a class within a class) similar to the example below.
Is this possible - or is there a workaround?
Cheers
class A{
 private:
   struct PrivateData
     int x;
     char y;
     float z;
   PrivateData m_PrivateData;
benc
Re: Inner class in C++
« Reply #1 on: November 19, 2003, 04:42:52 pm »
Hi billy_mumphry,
You may be able to use something like this:
1. Create class A
2. Create class PrivateData
3. Set the stereotype of PrivateData to "struct" and set its scope to "Private"
4. Create a nesting relationship from PrivateData to A
5. Create an association from A to PrivateData
6. Generate A
Warning: this approach only works for the forward generation of your class. Synchronisation of nested classes is not yet supported.
I hope this helps.
Ben
