Author Topic: Code Generation Templates  (Read 3071 times)
danman
« on: November 21, 2003, 10:41:09 am »
Where are the code generation templates stored? I looked in the registry and could not find anything that seemed like code templates.
Dan...
jkorman
Re: Code Generation Templates
« Reply #1 on: November 24, 2003, 08:13:27 pm »
Well it took a little looking around....
The code template defaults appear to be "stored" in TemplateResources.dll which
would imply the the "default storage" is the Sparx source code!
If you make changes, they show up in the t_template table of your model...
  But you should probably use
       Tools -> Export Reference Data
Only changes that were made using the template editor seem to show up in the table.
Hope this helps
Jim
danman
« Reply #2 on: November 24, 2003, 10:42:00 pm »
Thanks Jim,
Just minutes before I read your response I just happened upon the Tools | Export Reference Data menu item.
This is exactly what I needed. Thanks a lot!!
Dan...
