Author Topic: Test Case to Requirment COverage  (Read 3470 times)
edboyle
« on: December 03, 2003, 03:18:54 pm »
Hi All,
   I am relativley new to EA and was hoping to create a Requirement to Test Case Relationship Matrix to insure complete coverage. However, when create the Matrix and select Releationship to TestCase Matrix no test Cases that I have created appear. I have the Matrix selection as follows:
Source: Requirement, Tyoe: Requirement, Link: tried many.
edboyle
Re: Test Case to Requirment COverage
« Reply #1 on: December 03, 2003, 03:21:53 pm »
Hi All,
  Sorry, my first YABBC Post, hit the wrong key before I was done, as I was saying...
Source: Requirement, Tyoe: Requirement, Link: tried many. Target Requirement, Type: Test Case, Link: Tried Many.
Any help is appreciated I could not find what I needed in the EA help.
Thanks, Ed.
Bruno.Cossi
« Reply #2 on: December 03, 2003, 08:59:34 pm »
did you as a Target select really the package that contains your Test Cases?
Bruno
edboyle
« Reply #3 on: December 04, 2003, 05:55:39 pm »
   I beleive the problem is that the test cases defined in the Testing docked window are a separate
property of the Requirement - NOT something you can track in the matrix.
Thanks for the response, Ed.
Bruno.Cossi
« Reply #4 on: December 04, 2003, 08:42:02 pm »
Would not it be better than to use the actual Test Case object that is available in the EA? You could easily tie to the original requirement, you could use the Relationship Matrix and the testing would be much more transparent.
Bruno
