Author Topic: Version 4.00 - Build 723 Released  (Read 19854 times)
sparks
« on: March 25, 2004, 04:29:08 pm »
Release Notes for EA 4.00 Build 723
Modified EA to allow InteractionFragment to be a child element of another in the Project Tree
Modified list of elements in the Change Element Type dialog to include "Action" type
Fixed error with Change Object Type wherebye element is shown with home package text until diagram reloaded
Fixed error when moving elements with children between packages, whilst corresponding element open in tabbed view
Allowed saving of Selectable flag for elements currently not supported (eg. class, interface, note & etc) on per diagram basis
Fixed clipping problem with a small number of element types when producing RTF documentation and images
Modified drawing of object instances in Sequence diagrams to underline names
Fixed issue with unsaved elements losing recently set color values when same object moved in Project Tree
Fixed issue with creating new elements in SQL Server when template package was set and contained example of new element
Fixed issue with adding new diagrams to the Element.Diagrams collection in automation
Added ability to suppress sequence message parameters in message name by setting diagram "Show Parameter Detail" to None
Increased number of elements which are automatically set as children of ActivityPartition when adding and moving elements on Activity diagram
Modified drag drop handler in Project Tree to reduce number of database calls on action
Improved diagram display of embedded elements when they are moved from one element to another in the project tree
