Author Topic: Help setting synchronisation paths  (Read 3256 times)
dirc
« on: December 09, 2003, 05:42:27 am »
During a project, we totally changed the namespace and directory structure to match. However, when I try to synch the model with the code, EA looks for the original path. Look as hard as a might I cannot find a way to change the path for a packages source code.
Could someone please help  and tell me how I can do this.
Ta
Dirc
dirc
GraemeR
Re: Help setting synchronisation paths
« Reply #1 on: December 09, 2003, 02:59:07 pm »
Hi Dirc
Using 3.60.653 build.
Select a class, on the "Properties View" Under class settings, there is a field named "Filename" If you select this field, you will get a browser "..." elipsis on the right.
Note this is not the classes property sheet.
This field allows you to modify the target file for a class.
If you go to "Tools"->"Options"->"Generation"->"C++ Specifications" you will find a dialog for the default Source directory which may also prove useful for your work.
I hope this helps.
Cheers Graeme.
