Author Topic: C# Code Generation - finalize and code layout  (Read 4306 times)
jez
« on: January 08, 2004, 10:13:22 am »
Hi
I am having problems with Enterprise Architect creating 2 destructors - ~Object() (the one we all want) and protected virtual void Finalize (the one we don't!).
Does any one know any easy work around for this?
A couple of other code layout issues.
EA structures a method by closing the block at the end of the declaration i.e
public void Blah(){
I prefer the standard
public void Blah()
Any ideas how to change this?
Thanks in advance
Jez
danman
Re: C# Code Generation - finalize and code layout
« Reply #1 on: January 12, 2004, 09:58:27 am »
In order to change the format of generated code, you have to modify the code generation templates.
benc
« Reply #2 on: January 12, 2004, 02:47:40 pm »
Hi Jez,
Regarding the Finalize : you can turn off the automatic generation of this from the Code Generation options.
Select your class, hit cntrl+G -> Advanced -> C# Specifications. You can change the default setting under Tools | Options | Generation menu.
Regarding the brace style : you will need to customize the code generation templates. In particular, the default Operation template. Replace the line with %PI=""% to %PI="\n"%. You'd also need to update the templates responsible for generating get/set methods in properties etc. The help file has some more info on customizing code templates.
I hope this helps.
Ben
Just an update: We'll add a sanity check to the templates so that either a Finalizer or Destructor stub (not both) get auto generated.
« Last Edit: January 12, 2004, 03:12:44 pm by benc »
