Author Topic: Importing MySQL data model  (Read 3653 times)
alauzon
« on: January 01, 2004, 07:57:56 am »
Hi there Enterprise Architect is a wonderful tool.  ;)
I would like to know if somebody tried to import the data model from a MySQL database through an ODBC link or any other way ?
Can you share with me your results since I don't understand how to do that ?
Alain Lauzon
Englisito
  • Wibble, Wibble, Fish
Re: Importing MySQL data model
« Reply #1 on: January 16, 2004, 12:19:55 am »
I just did an import today so its fresh in my head:
  • First setup the ODBC data source on your machine.
  • Create a package to put it in and a class diagram. I used the default deployment view, its deployment model and deployment diagram.
  • Open the diagram.
  • Select Project->Database Engineering->Import from ODBC.
  • Set the database name using the "...". It should be in the 'Machine Data Source' tab of the dialog.
  • Then Import.
  • Here you can select the Tables you want then OK it.
The table elements etc. are created and displayed in your diagram.
I think it works out its MySql automatically and uses the data types as defined in Configuration->Database Datatypes.
The only problem I had was it seemed to lose some data type definitions and I could not work out how to edit things like field length. Looking into both of these.
Once this is solved I should be able to use the models to generate DDLs.
Hope this helps
