Author Topic: Where's the Functional Spec documents?  (Read 2827 times)
Julieb
« on: January 15, 2004, 08:06:37 pm »
Hello
We're evaluating your product and can't seem to generate a Functional Specification or anything like?
Do you call it something else?
Would be grateful if you could advise... we're close to buying...
Julie
Tjerk
Re: Where's the Functional Spec documents?
« Reply #1 on: January 15, 2004, 11:44:44 pm »
Hi Julie,
There are two ways.
1. Functional requirements can be added to each package in the projectbrowser by using: Insert, New Element..., select Type Requirement and give the element a new (mostly a number and a title);
2. When you have elements (e.g. Analysis objects, use cases, actors, classes) you can open the properties window. That window contains a number of tabs, one of them is the Require tab. Here you can enter the details of (functional) requirements that are only associated with the element (could be "externalised" later, to be associated with other elements, or to e.g. improve visibility).
Hope this is what you're looking for.
Greetings,
Tjerk
Julieb
« Reply #2 on: January 18, 2004, 03:46:54 pm »
Hey thank you
We just found it hard to find standard doco.
We'll have a look.   :o
Julie
