Author Topic: Import C++ class & storage-class modifier  (Read 3451 times)
sikora
« on: January 29, 2004, 05:39:39 am »
If I use storage-class modifier in C++ source code then the reverse engineering process creates a class with the name of storage-class modifier. If I have defined more of such classess in one source file then the reverse engineering process is in progress without finishing and I have to cancel the application Enterprise Architect. :(
example from source code:
class DllExpImp CListMstItem : public CList<tstMstItem, tstMstItem&>
class name is CListMstItem but the class DllExpImp is created
Have I to remove the storage-class modifier before the reverse engineering process or is there any other way ?
Thank you for any help.
« Last Edit: January 29, 2004, 05:45:50 am by sikora »
benc
Re: Import C++ class & storage-class modifier
« Reply #1 on: February 01, 2004, 02:12:03 pm »
Hi sikora,
I think this post may be related to this issue:
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.cgi?board=general;action=display;num=1073200530;start=1#1
Basically you can define DllExpImp as a C++ macro and EA will ignore it during import.
I hope this helps.
Ben
sikora
« Reply #2 on: February 02, 2004, 12:12:51 am »
Thanks a lot for your answer.  :)
It was exactly what I needed.
