Author Topic: Set target DBMS  (Read 2712 times)
jdoran
Set target DBMS
« on: February 02, 2004, 10:10:06 am »
This is a newbie question, not with UML, but EA in particular.
I'm creating a data model for a simple schema and I've created a class with the stereotype table.   When I add columns, I can't select a Data Type since it's blank.  The help page states that I should go to the class Properties, Table Detail tab and set the database to the target DBMS.
How does one set the target DBMS on that dialog?  The only options are
1. Table Space
2. Column/Attributes
3. Operations
4. Generate DDL.
What am I missing?
Thanks for your help.
jdoran
Re: Set target DBMS
« Reply #1 on: February 02, 2004, 10:21:35 am »
Nothing like explaining a problem to present a solution.  I returned to the Properties dialog and there is a Database Selection as plain as day.
Now where was that hiding the first 3 times I went to that dialog  ;D
