Author Topic: Duplicate operation after reverse engineering Java  (Read 3710 times)
struesda
« on: February 06, 2004, 01:51:23 pm »
When reversing a java class with a method:
protected GenericRecordCollection retrieveDetailsForOrder(int pToOrderId) throws OrderException
which was changed from public to protected
the corresponding class in EA has an additional operation added for the protected method - but the pre-existing public version is not removed - even though my preferences are set to 'On Syncronize, delete model methods not in code'
I am using EA 3.60.656
Any idea why this is happening?  Can it be fixed?
  Steve Truesdale
benc
Re: Duplicate operation after reverse engineering
« Reply #1 on: February 10, 2004, 09:40:51 pm »
Hi Steve,
I've tried to duplicate this behaviour using your example method and a simple java class. It seems to be working ok- the existing method gets updated with protected scope in the model ...
Is it possible you could send us a small example source file that isolates this problem (mail to [email protected]). If you can provide the detailed steps you took in the mail,  we'll try to get this resolved promptly.
Ben
