Author Topic: Code generation  (Read 4092 times)
Lambert
Code generation
« on: February 17, 2004, 01:56:28 am »
Hello all,
I'm having troubles with code generation.
I try to generate code from the project tree. A package contains 10 class or so. But I can only select 2 classes.
From the diagram view I can generate every class I want. But generating a complete package is not possible.
I'm using EA 3.60.658.
Does anyone have an idea?
Groetjes,
Lambert
Sean Kearon
Re: Code generation
« Reply #1 on: February 17, 2004, 04:31:10 am »
Have you checked the "include all child packages" setting in the generate code dialog?
Lambert
Re: Code generation
« Reply #2 on: February 18, 2004, 12:48:47 am »
Yes, I did check "include child packages"
benc
Re: Code generation
« Reply #3 on: February 18, 2004, 07:12:03 pm »
Hi Lambert,
Build 659 resolved an issue related to this. I would recommend downloading the latest release.
I hope this helps.
Ben
Lambert
Re: Code generation
« Reply #4 on: February 19, 2004, 05:58:12 am »
EA 3.60 build 660 indeed solved the problem.
:D
Thanks a lot!
Lambert
