Author Topic: Shared Packages, Version Control etc.  (Read 3980 times)
ditlev
« on: March 02, 2004, 06:44:34 am »
I have a problem with the use of items mentioned in subject.
I have a master EA project holding the application framework package. This package is both version- and package controlled (using VSS). Works fine.
Every week our application framework library is built (new increment).
In order to get the latest framework for development/design/modelling purpose the '.NET Class Library Exporter for EA' is used to reverese engineer the built dll's.
My problem is this.
Elements used in models from a previous build disappear when the new build is imported.
How do I avoid this?
Sean Kearon
Re: Shared Packages, Version Control etc.
« Reply #1 on: March 02, 2004, 09:06:11 am »
EA overwrites the package into which you are importing.  So, one option is to import into a seperate package in your model for each build.
Does that help?
Sean
ditlev
« Reply #2 on: March 02, 2004, 12:21:29 pm »
Not really since im trying to avoid re-modelling by developer teams.
D
