Author Topic: C# Struct implementing interfaces  (Read 5560 times)
kossmann
« on: March 09, 2004, 01:05:46 pm »
I forward engineer from EA structs (struct stereotype as opposed to a class). My structs have attributes, and also implement one or more interfaces.
When I reverse engineer a struct such as
internal struct MyStruct : ICompare
     internal int i1;
     internal int i2;
     int CompareTo(object obj){
           return i1 - ((MyStruct)obj).i1;
it works fine, but then when I forward engineer that again, the Interface being implemented disappears, ie. the forward engineering produces:
     internal int i1;
     internal int i2;
Any ideas?
Rainer
benc
Re: C# Struct implementing interfaces
« Reply #1 on: March 10, 2004, 10:32:42 pm »
Hi Rainer,
Thanks for the note.
This is caused by an error in one of the the C# code generation templates.
We will fix this for release of EA 4.0.
As a short term work around, you can override the default C# "ClassInherits" code template for the struct stereotype:
1. Open the Code Template Editor (Ctrl+Shift+P)
2. Select C# as the language
3. Select the ClassInherits template
4. Select the struct stereotype override
5. Replace the line :
$interfaces=%list="ClassInterfaces" @separator=", "%
with
$interfaces=%list="ClassInterface" @separator=", "%
6. Click save
Next time you generate the interface should appear.
I hope this helps.
Ben
kossmann
« Reply #2 on: March 11, 2004, 07:15:15 am »
Thanks, Ben. That did the trick.
Rainer
