Author Topic: Class diagram does not show relationships  (Read 4139 times)
mber12
« on: March 11, 2004, 07:44:05 am »
I used 'import directory structure' to reverse engineer a java package and I am seeing the class diagram but the diagram does not show relationships between the classes.
Did I miss a step or is there some otherway in EA to reverse engineer java class files such that the relationships are visible?
Thanks for any comments...
CJ
Re: Class diagram does not show relationships
« Reply #1 on: March 11, 2004, 08:15:14 am »
G'day g'day,
By any chance, is your diagram set to hide relationships?
Cheers and best regards.
mber12
« Reply #2 on: March 11, 2004, 08:22:22 am »
Where can I tell if I am hiding relationships?  I looked around but I can't find any option controlling that.  Thanks.
mber12
« Reply #3 on: March 11, 2004, 08:26:02 am »
OK - just found it in diagram propeties but the checkbox to hie relationships is not checked.  I am probably using default settings for all diagrams.  I merely imported the directory of java class files.  Thanks for you help...
