Author Topic: Aggregation to self  (Read 7150 times)
KirilD
Aggregation to self
« on: March 09, 2004, 01:21:45 am »
I'm trying to create an aggregation from a class to itself, and am having a problem. Namely, I cannot get the aggregation to appear on screen. It exists, and appears in the links section of the class properties, but I can't seem to do anything to get it to appear on screen.
Normal associations appear fine.
Thanks for any help,
Kiril
fluxtah
Re: Aggregation to self
« Reply #1 on: March 09, 2004, 04:21:42 am »
I get this problem too  :-[
« Reply #2 on: March 09, 2004, 06:22:17 am »
Look at jvogt's reponse earlier in this board.
Thomas
KirilD
« Reply #3 on: March 09, 2004, 02:15:45 pm »
Thanks, jvogt's solution works.
This is then, I assume, a bug. Has it been reported as such? Are there any plans to fix it?
Kiril
fluxtah
« Reply #4 on: March 09, 2004, 02:17:42 pm »
Hiya,
I just updated my EA to the latest build, works fine now.
regards
Ian
KirilD
« Reply #5 on: March 09, 2004, 02:20:57 pm »
Was that 3.60.662 or the beta of 4?
Kiril
fluxtah
« Reply #6 on: March 09, 2004, 02:37:58 pm »
was 662,
regards
Ian
KirilD
« Reply #7 on: March 09, 2004, 08:53:06 pm »
I'm running 662, and still have this problem.
Also, with jvogt's solution, I get an arrow appearing at the diamond end, and nothing I do can remove it - changing the direction of the aggregation leaves it there, as does setting it to bi-directional or unspecified.
Kiril
fluxtah
« Reply #8 on: March 10, 2004, 03:57:46 am »
strange, not sure what the prob here is then, seems to be working for me now but will experiment when I get home, we have EA at work but it has not ben installed for me yet  >:(
mbc
  • Embedded software developer
« Reply #9 on: March 10, 2004, 04:43:03 am »
Just out of curiosity, because I might have the wrong idea about aggregations:
An aggregate is a class that consist of one or more parts, isn't it? How can a class be part of itself? This seem like an infinite recursion to me.
Am I getting something wrong?
Mikkel
jvogt
  • software engr in training
« Reply #10 on: March 10, 2004, 07:40:37 am »
Hello All,
I did submit this as a bug. I am also getting the unmoveable arrow on the aggregation.
The best example I can think of for self-aggregation is a node in a tree. Each parent node will contain references to its child nodes. (Parent and child nodes are of the same type.)
Jesse
JourneymanDave
« Reply #11 on: March 10, 2004, 09:31:52 am »
Mikkel, a composition is a type of aggregation that defines physical containment of the type you're thinking of.  Like Piston, Valve and Crankshaft objects composing an Engine object.
benc
« Reply #12 on: March 11, 2004, 07:24:01 pm »
Hi Guys,
Thanks for your comments.
The bug preventing the display of self-aggregation has been noted- we will fix this ASAP.
The unmovable arrowhead results from a limitation which only allows self-associations  to have "Source to Destination" direction. There is work in the pipeline to make self-associations/aggregations more flexible for future releases of EA.
Ben
