Author Topic: How to make Java the default for cogeneration  (Read 5683 times)
svedloff
« on: March 23, 2004, 04:07:17 pm »
Nice tool.  I designed some diagrams, and now I am trying to generate some code.  For every class, I have to go in and change the default code generation language from C++ to Java.  There doesn't seem to be any way to do it on a global level.  Any help would be appreciated.
Rob_M
Re: How to make Java the default for cogeneration
« Reply #1 on: March 23, 2004, 05:22:11 pm »
Go to the tools menu -> options
Select Generation.
Change default language for code generation to language of choice.
Rob M.
restrick
« Reply #2 on: March 23, 2004, 05:38:01 pm »
I have a model into which I've imported a Visual Basic (vb6) project.  I would like to export the code as vb.net files but, as of right now, I have to go into each class and set its language to vb.net from visual basic manually, else the code generation wizard defaults to generating files in visual basic.
If I shift+select a group of classes in the diagram and try to change the property in the "Properties" window, it is disabled.
Changing the "Default Language for Code Generation" option under tools->Options didn't help.
Is there a way to do this via the api or the UI???
Thanx in advance.
Sean Kearon
« Reply #3 on: March 24, 2004, 01:45:12 am »
Hi Restrick
Right-click the package, select Code Engineering and 'Reset options for this package'.  Assuming you are using 4.0.
Sean
