Author Topic: Association link name with little black arrow  (Read 10648 times)
fluxtah
« on: March 24, 2004, 09:17:43 am »
How do I make an association link name with those little black filled arrows showing direction, ie showing how
|child|-----becomes > ---- |adult|
« Last Edit: March 24, 2004, 09:19:10 am by fluxtah »
sargasso
Re: Association link name with little black arrow
« Reply #1 on: March 24, 2004, 11:57:37 am »
Right click on the label, then select "Direction".
B
fluxtah
« Reply #2 on: March 24, 2004, 01:48:08 pm »
Hi sargasso
That just gives me the normal association arrow, i guess it represents the same thing?
regards
fluxtah
« Reply #3 on: March 24, 2004, 02:02:20 pm »
Hi fluxtah,
this arrow is normally used with ERD to show the type of relation (is part of; builds; etc.). I have not seen a way to produce these arrows in EA, although it would be nice to have them. You can use directed asociations as Bruce suggested but in that case you can denote just one direction.
Thomas
fluxtah
« Reply #4 on: March 24, 2004, 02:26:49 pm »
Ah I see :( just reading UML 2.0 Toolkit book which refers to the type of association Bruce suggested as a 'navigable association' by adding an arrow at the end of the association though I wanted the one you described as those used with ERD.
I wanted to do something like this:
                                           Owns >
|Person|---------------------------------------|Car|
                                          < Owned By
would be nice to do this :D any suggestions on alternatives?
regards
fluxtah
« Last Edit: March 24, 2004, 02:27:21 pm by fluxtah »
sargasso
« Reply #5 on: March 24, 2004, 04:07:09 pm »
Are you sure you are right clicking on the label, not the link?
B
benc
« Reply #6 on: March 24, 2004, 04:34:53 pm »
Hi fluxtah,
the reading direction is a property of the link name/label as Sargasso noted.
I just updated a previous thread related (I think) to this issue.
Ben
fluxtah
« Reply #7 on: March 25, 2004, 12:08:59 am »
Ah cheers :D I was clicking on the link  :-/ Cool I got my arrow now, though is it possible to add 2 labels to one link?
regards
Ian
« Last Edit: March 25, 2004, 12:19:35 am by fluxtah »
Andreas_G
  • And that's the way the cookie crumbles.
« Reply #8 on: March 25, 2004, 02:44:32 am »
I think UML accept only one label to one link.
correct me if I'm wrong.
bye
Andreas
« Reply #9 on: March 25, 2004, 04:13:19 am »
Could not find any restriction in the UML documentation (which does not mean that there is none  ;)). The examples shown make use of only one label. But with ERD one usually has two labels (forth and back).
Thomas
p.s.: this is what the spec says:
Note – There is no need for a name direction property on the association model; the ordering of the classifiers within the association is the name direction. This convention
works even with n-ary associations.
« Last Edit: March 25, 2004, 04:18:00 am by thomaskilian »
fluxtah
« Reply #10 on: March 25, 2004, 06:27:59 am »
According to the UML2.0 toolkit, they have 2 labels on many examples :(
regards
Ian
« Reply #11 on: March 25, 2004, 07:38:23 am »
Actually I was looking in the 1.5 specification. But 2.0 also does not make use of 2 labels:
On a binary association drawn as a solid line, a solid triangular arrowhead next to or in place of the name of the
association and pointing along the line in the direction of one end indicates that end to be the last in the order of the ends
of the association. The arrow indicates that the association is to be read as associating the end away from the direction of
the arrow with the end to which the arrow is pointing (see Figure 31).
Figure 31 shows only one single arrow near a single label.
Thomas
fluxtah
« Reply #12 on: March 25, 2004, 08:16:23 am »
Hiya, this is actually very confusing, considering I am going by the UML2.0 Toolkit on OMG Press, tells me that they are showing me official standards, unless OMG themselves have got it wrong?  ???
They use this example as above
                                                 Owns >
                                             < Owned By
Which makes me wonder how they are able to do this if it is not part of UML2.0
regards
Fluxtah
« Last Edit: March 25, 2004, 08:16:46 am by fluxtah »
sargasso
« Reply #13 on: March 25, 2004, 02:33:09 pm »
Use rolenames!
