Author Topic: how to work with [] type arrays?!  (Read 7376 times)
fluxtah
« on: February 02, 2004, 10:47:00 am »
When forward engineering from a model I am able to generate associations with multiplicity by setting the collection classes option of a class to the desired name of the collection ie- 'Book[]'
When synchronising the model I loose the association links because EA does not recognise that Book[] is collection of Book.
Anyone know how to solve this prob?
- Fluxtah
« Last Edit: February 02, 2004, 10:55:39 am by fluxtah »
Sean Kearon
Re: how to work with [] type arrays?!
« Reply #1 on: February 03, 2004, 01:29:23 am »
I reported this as a bug in late November last year and got a reply that they were going to fix it.  If I remember right, you get an attribute when you reverse engineer, as opposed to an association.  They usually fix issues swifter than this - maybe it's been overlooked.
Sean
fluxtah
« Reply #2 on: February 03, 2004, 03:30:43 am »
cool, on forward engineer it seems to do what I want it to do from an association, if i link to classes via an association, set the target role or source role to a some name, then set the data type field to the target type with [] after it the code will forward engineer fine.
I can also acheive this by setting the collection class option under the class properties.
prob is when synchronise/ reverse engineer the fwd engineered attributes with multiplicity are unrecognised, stripping away any associations I had.
I can get round the issue by not synchronising.
Sean Kearon
« Reply #3 on: February 03, 2004, 03:33:28 am »
Maybe reporting it as a bug again would move it along a bit.  I guess they are flat out getting version 4 ready to ship at the moment.
fluxtah
« Reply #4 on: February 03, 2004, 04:04:13 am »
cool! that is a good thing :] I think after scanning the boards the question about [] array notation has been asked enough.
I will leave them to dev v4!
- Fluxtah
« Last Edit: February 03, 2004, 04:04:53 am by fluxtah »
benc
« Reply #5 on: February 10, 2004, 07:23:40 pm »
Hi Fluxtah and Sean.
Just to confirm, we are aware of this bug and it will be fixed.
Ben
fluxtah
« Reply #6 on: February 11, 2004, 03:59:31 pm »
Quality :]
« Reply #7 on: April 06, 2004, 04:32:42 pm »
Hi everyone
I just want to report that support for this has been fixed so look out for the fix in a build coming soon.
When you import a class with a variable such as
Book[] a;  It should import with no problems, the type will be Book and the collection will be [].  It should then output as well.
Additionally, if this is the return type of a function then it will set the return array checkbox.
Simon
