Author Topic: Deleting Unused Diagram Elements  (Read 8678 times)
brian
« on: April 09, 2004, 01:44:06 pm »
Is there a way to identify and delete unused elements that appear in the project tree but are not used on the current diagram?
If I right-click on an element in the tree I can identify and delete individual elements by looking to see if "Locate in Current Diagram" is enabled, but I'm hoping there is an easy way to do this en-mass.
Thanks in advance!
-- Brian
mbc
  • Embedded software developer
Re: Deleting Unused Diagram Elements
« Reply #1 on: April 12, 2004, 01:52:59 am »
If you use the Find feature and check "Find orphans", you will find elements that are not used in any diagram (not only the current one). I have been told it is possible to delete multiple elements from there.
From the project tree you can use "Show usage" (Ctrl-U) to find out where or if an individual element is used.
Mikkel
brian
« Reply #2 on: April 12, 2004, 09:44:11 pm »
Thanks Mikkel... deleting orphans from the find feature works great!
-- Brian
« Last Edit: April 12, 2004, 09:45:04 pm by brian »
