Author Topic: Java Automation Interface compile errors  (Read 3840 times)
dmcwhinnie
« on: May 18, 2007, 08:12:07 am »
I'm getting bad version errors when trying to compile th Java Interface.  I'm using Java 1.5 anyone else done this?
C:\jdevstudio10132\jdk\bin\javaw.exe -client -classpath "C:\jdevstudio10132\jdev\mywork\EA DDL\Client\classes;C:\Program Files\Sparx Systems\EA Trial\Java API\eaapi.jar" client.Class1
Exception in thread "main" java.lang.UnsupportedClassVersionError: Bad version number in .class file
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:124)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:268)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
at client.Class1.main(Class1.java:12)
Process exited with exit code 1.
jkorman
Re: Java Automation Interface compile errors
« Reply #1 on: May 18, 2007, 12:12:28 pm »
There is a file SSJavaCOM.dll that must be visible to the jre you are running. I place mine in JAVA_HOME\bin, works fine.
Make sure that you are using the same version of the dll as the associated JavaCOM_API.jar.
Jim
« Last Edit: May 18, 2007, 12:14:44 pm by jkorman »
dmcwhinnie
« Reply #2 on: May 21, 2007, 04:55:06 am »
I tried placing the .dll in the java bin folder, and that doesn't work.  you mention the JavaCOM_API.jar file.  I don't have this jar file, I only have eeapi.jar.  Where would I find this jar file?
What version of Java should I be using?
« Last Edit: May 21, 2007, 05:04:29 am by dmcwhinnie »
dmcwhinnie
« Reply #3 on: May 21, 2007, 05:22:22 am »
Turns out I needed a newer Java version.  Installed 1.6 and it seems to be working now.
