Author Topic: Linking Web Documentation to Word Files  (Read 2568 times)
brian
« on: April 22, 2004, 03:21:31 pm »
I have some use-cases with links to Word files.  The links work fine from within EA, but when I generate Web (HTML) documentation the links only work if the file types are RTF instead of DOC.  Does anyone have a work-around for this?
Any suggestions would be helpful.  Thanks in advance...
Brian
MichaelHanson
  • EA is the best
Re: Linking Web Documentation to Word Files
« Reply #1 on: April 27, 2004, 12:27:34 pm »
Not really a workaround, but I got around this by adding two links to files, one for use in EA with the default type of Local File, using a UNC path then another with the type set to Web Address using a relative URL.
Had to educate users and team members to use the correct link when viewing HTML version, but it worked
Mike Hanson
Microsoft Technology Specialist
