Author Topic: Underlined instances in sequence diagrams  (Read 3549 times)
eperales
« on: April 27, 2004, 04:14:00 pm »
Hi all,
In a sequence diagram, what is the diference between :
1) Dropping a lifeline from the toolbox and then setting his classifier ( Ctl-L ) , and
2) Dropping a class from the project view as a instance of element.
I expected the final result to be the same but it is not. In the first case I get a underlined instance ( good ), in the second I don't ( not good ). Even the icons in the project view are not the same.
Adiós
PS : Im using EA4
Andreas_G
  • And that's the way the cookie crumbles.
Re: Underlined instances in sequence diagrams
« Reply #1 on: April 27, 2004, 11:21:45 pm »
which Build of EA4 you are using?
That what you describe, sounds like a bug which is fixed in Build 723.
Have a look at http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.cgi?board=Latest;action=display;num=1080260948
bye
Andreas
bye
Andreas
eperales
That was it!
« Reply #2 on: April 28, 2004, 07:02:42 am »
Thank you! It was driving me nuts!
