Author Topic: creating generalization when synchronizing problem  (Read 2941 times)
Christiaan
« on: April 29, 2004, 05:45:05 am »
I use ea 4.00 build 7.22. I have generated java classes using ea. I modified some of the classes and chose Code engineering | Synchronize package contents | reverse engineering in EA
EA suddenly generates generalization relations in my diagram to one particular class which aren't there in the code and were not there in the diagram I constructed. Can someone help me with this?
kind regards,
Christiaan
Javier
  • Necessity is the mother of email
Re: creating generalization when synchronizing pro
« Reply #1 on: April 29, 2004, 09:05:12 am »
It seems to me that EA still has glitches when reverse engineering code--sometimes code originally generated with EA.
Try reverse engineering the same code in another model, and if it gives you the same results--the generalization--then submit it as a bug.
Javier
We must become the change we want to see.
- Ghandi
