Author Topic: Mapping Class Diagram to Data Model  (Read 4071 times)
Patrick
« on: May 11, 2004, 06:47:46 am »
How can I map Class Diagram to Data Model using EA?
Re: Mapping Class Diagram to Data Model
« Reply #1 on: May 11, 2004, 11:15:57 am »
Select the package. Right click. Select Code Engineering/Generate DDL.
Patrick
« Reply #2 on: May 12, 2004, 12:49:13 am »
Hi Thomas;
thank's for your suggestion. But, described procedure isn't work with Class Diagram Packages. This one is relevant for Data Model, where I may select offered tables.  :-/
CJ
« Reply #4 on: May 12, 2004, 07:29:53 am »
G'day,
Just in case this is of use:
I was searching for something completely unrelated ("UML" and "WM_") in Google when I happened upon the following...
http://www.methodsandtools.com/archive/archive.php?id=9
« Last Edit: May 12, 2004, 07:59:08 am by jasonv »
Cheers and best regards.
« Reply #5 on: May 12, 2004, 07:35:51 am »
Cool. How did you find this one?
Patrick
« Reply #6 on: May 12, 2004, 07:39:30 am »
Thanks so much  ;D That's it what I need  ;)
