Author Topic: Reverse Engineer Context Menu  (Read 2670 times)
MLibby
« on: May 13, 2004, 03:19:37 pm »
I just downloaded the EA 30 Trial and am trying to reverse engineer my application.  I'm following the following help steps:
To import source code (reverse engineer) you will usually do the following:
1. Select (or add) a diagram from the Project Browser into which the classes will be imported
2. Right click on the diagram background to bring up the diagram context menu and select Import from source file(s). From the submenu, select the required language
I added a new class diagram, open it up, right click on the diagram and do not see Import on the context menu.  What am I doing wrong?
sargasso
Re: Reverse Engineer Context Menu
« Reply #1 on: May 13, 2004, 03:21:27 pm »
Use the Code engineering item in the Project menu.
hth
Bruce
MLibby
« Reply #2 on: May 13, 2004, 05:23:45 pm »
I'm really feeling like a newbie here.  There isn't a code engineering item in the project menu.
The EA version I downloaded is ver 3.60.661.  Is this correct?
