Author Topic: How to depict other dependencies in UML  (Read 5374 times)
gluzm
« on: May 18, 2004, 11:26:42 am »
I created four examples of code and UML model to it.
OwnerEx1 – association
OwnerEx2 – composition
But how to depict the dependencies for the last 2 examples
OwnerEx1 and OwnerEx2
Jan
namespace UML
     /// <summary>
     /// asociation
     /// </summary>
     public class OwnerEx1
           private Owned _owned;
           public OwnerEx1(UML.Owned owned)
                 _owned = owned;
     /// <summary>
     /// composition
     /// </summary>
     public class OwnerEx2
           public OwnerEx2()
                 _owned = new UML.Owned();
     /// <summary>
     /// </summary>
     public class OwnerEx3
           public OwnerEx3()
                 UML.Owned owned;
     /// <summary>
     /// </summary>
     public class OwnerEx4
           public UML.Owned GetOwned()
                 return new UML.Owned();
     public class Owned
Re: How to depict other dependencies in UML
« Reply #1 on: May 18, 2004, 01:26:51 pm »
Tried to reverse engineer that code?
gluzm
« Reply #2 on: May 19, 2004, 01:26:24 am »
Yes the ressult is presented in the diagram
Jan
gluzm
« Reply #3 on: May 19, 2004, 01:29:01 am »
Actually what is interesting is that EA did not recognized the composition. I have to change it.
Jan
angel-o-sphere
« Reply #4 on: May 19, 2004, 03:30:24 am »
You draw dependencies to Owned with stereotypes like <<returns>> and <<creates>>.
<<returns>> is likely also a creation otherwise you had a reference I guess. If you could attach the dependency on the operation ... <<returns>> would be suiting.
You can invent stereotypes in such situations, its only important that you are consistent and your team agrees with you in their usage.
Instead of <<creates>> in our days <<instanciates>> is used as well, but that one is most of the time used in class to object dependencies.
angel'o'sphere
gluzm
« Reply #5 on: May 21, 2004, 04:32:08 am »
Yes thank you, I was thinking that this must be solved by stereotypes.
But then <<returns>> sounds for me also not unambiguously, instance <<returns>> instance (when not static class) so then it will be suitable in object model, but for classes it is misleading.
Actually I can not imagine such code example except static class, my opinion it is not good approach to return something without keeping a reference to it. This is against destruction handling.
But what stereotype to use if the class is instantiated in the method scope?
Jan
