Author Topic: Is there a Route Around option?  (Read 3547 times)
Robert DiFalco
« on: May 28, 2004, 10:09:59 am »
Is there a way I can force a dependency (or other type of line) to route around objects?
fluxtah
Re: Is there a Route Around option?
« Reply #1 on: May 29, 2004, 04:44:29 pm »
If you right click on the line choose Toggle line point at cursor from the context menu will allow you to manouver an line around objects, not sure of any automatic way to do it.
hth
Fluxtah
Robert DiFalco
« Reply #2 on: May 29, 2004, 05:17:01 pm »
I'm evaluating build 726. Unless I'm missing something, I do not see that option.
« Reply #3 on: June 01, 2004, 03:45:30 am »
Try right-clicking the line and select  "set line style". Pick custom line and you can do what fluxtah sayed.
mchiuminatto
« Reply #4 on: June 01, 2004, 06:54:09 am »
You can set the line style to auto routing. Right click the connector then select Set Line Style Option -> Auto Routing  or you can use the shortcut : Shift+Ctrl+A
Regards.
Marcello
