Author Topic: Problem with swimlanes (rookie)  (Read 2977 times)
cgarski
« on: June 09, 2004, 01:04:01 pm »
Posting this on behalf of a few of us rookies who just started with EA and are still learning.  We're having a problem with adjusting swimlanes.....
When I try to make a swimlane wider, I click on the swimlane and try to drag the line up or down to adjust the swimlane width.  When I click on the swimlane, the line disappears and moves down to the bottom of the diagram, usually a few pages down.
I cannot find a way to move the swimlane back up to the correct position in the diagram since whenever I 'click' on the line, it disappears.  Using the Configure Swimlanes dialog to move a swimlane doesn't work, it just swaps a different swimlane down several pages.
Can anyone help with a solution?  Thanks!
Takeshi K
    • Sparx Systems Japan
Re: Problem with swimlanes (rookie)
« Reply #1 on: June 10, 2004, 06:12:33 am »
Hello cgarski,
If you don't use newest build, please try again under build 729.
In some older build, there was a problem you mentioned
and maybe it's fixed in newest build.
tkouno
t-kouno
cgarski
« Reply #2 on: June 10, 2004, 10:33:21 am »
We were using build #728.  The problem does indeed seem to have been corrected with build #729.
Thanks!
