Author Topic: View constraints of use case  (Read 3942 times)
ericf
« on: June 14, 2004, 10:31:38 am »
I can add constraints to a use case with the use case properties dialog, but I can't find a way to have those constraints displayed in the use case model.
According to the EA docs, Element Features -> Specify Feature Visibility... Show Element Compartments [] Constraints should do it.  Also tried Show Constraints in the diagram properties, with no success.
This does work for other types -- classes, objects -- just not for use cases.  I wrote to sparx support and haven't heard anything back.  Is this a known defect or is it operator error?
kamil.svoboda
Re: View constraints of use case
« Reply #1 on: June 14, 2004, 11:18:56 pm »
You have to switch to rectangle notation, for displaying constraints of use case.
Use right click on the use case and choose Use Rectangle Notation.
Kamil
johnr
« Reply #2 on: June 14, 2004, 11:19:11 pm »
To display a constraint in a use case, you can use the following steps:
°      Select the element that you wish to display the constraint
°      Right Click the element to bring up its context menu
°      Mouse over the attach option and select the attach constraint option
°      Type in the constraint
Hope that helps
ericf
« Reply #3 on: June 15, 2004, 09:21:05 am »
Thanks Kamil -- using rectangle notation does the trick.
