Author Topic: Java Code generation  (Read 2512 times)
JimKirk
« on: June 23, 2004, 02:30:44 am »
I evaluate the Enterprise Architect 4.0 to use it in our company.
But I found a problem, when I generate JAva Source Code.
In the package and import statements are the wrong code:
package Use Case View.Use Case Model.com.company.test.ea;
import Use Case View.Use Case Model.com.company.test.ea2.SuperTest;
Why is the text Use Case View.Use Case Model before the package name? Exists an option in ea where I can deactivate to Use the View Name by code generation?
Thx Werner
Re: Java Code generation
« Reply #1 on: June 23, 2004, 03:07:22 am »
probably you should read the help you find when opening Project/Namespaces...
angel-o-sphere
« Reply #2 on: June 23, 2004, 03:18:13 am »
Right click on package "com". Select "set as namespace root".
angel'o'sphere
