Author Topic: Configuring Local Directories  (Read 2995 times)
tathata
« on: June 18, 2004, 08:31:49 am »
I have created my own language datatypes and code generation template for ActionScript 2.0.
I would like to setup a local directory for my "user defined language".  When I open the local directory configuration window I only get options for setting up local directories for the built in languages.
Is there any way to do this or should this be a new feature request?
Re: Configuring Local Directories
« Reply #1 on: June 22, 2004, 09:04:40 pm »
The dialogue currently doesn't support custom languages although it shouldn't be long until it does.  ;)
There is a solution before then though.
The local directories are stored in a file called paths.txt in your EA directory.  You can edit it directly to add paths for custom languages.
Simon
« Last Edit: June 22, 2004, 11:34:33 pm by simonm »
tathata
« Reply #2 on: June 23, 2004, 06:46:22 am »
Excelent!
Thank you for all the help!
I have been using EA for a couple weeks now and it is really a great program and the support I have received from the forum has helped a lot!!
