Author Topic: Composite Elements - A Question  (Read 9877 times)
jedwards
« on: June 07, 2004, 08:18:37 am »
Hi all,
When I mark a class as a "composite element" EA automatically creates a new diagram and links the class to it.  Is there any way to link a composite element to an existing diagram instead of the new one?
Jon
« Last Edit: June 07, 2004, 08:19:52 am by Jon_Edwards »
Re: Composite Elements - A Question
« Reply #1 on: June 07, 2004, 08:36:22 am »
Why not drag the existing diagram to the newly created and delete the latter?
sargasso
« Reply #2 on: June 07, 2004, 04:09:06 pm »
Usual way i handle this is to
1) change the element to compositre
2) drag the existing diag to beneath th element
3) delete the element that was auto created,
Bru ce
pls forgive typeing - ive got a sprained thumb
Bruno.Cossi
« Reply #3 on: June 09, 2004, 09:02:39 pm »
Or one step easier:
1) Drag an existing diagram under the element
2) Change the element to composite
Bruno
sargasso
« Reply #4 on: June 09, 2004, 10:16:32 pm »
Have found that your method almost always works.....
B
Bruno.Cossi
« Reply #5 on: June 09, 2004, 10:20:29 pm »
Just out of curiousity, when it does not work? I have really not used it with all the range of elements...
Bruno
kamil.svoboda
« Reply #6 on: June 09, 2004, 11:37:34 pm »
Is it possible to create child diagram (for example child sequence diagram for the specific use case) and than create link (not move instance of the diagram) to another package (for example to package Sequence model)?
Kamil
sargasso
I can find anytRe: Composite Elements - A Question
« Reply #7 on: June 09, 2004, 11:53:45 pm »
Bruno,
I've not really analysed it, and haven't checked for several releases. It wasn't anything obvious IIRC.
So, I just got used to doing the 3 step way and haven't ever had a problem.  I'll revert to the two-step and see if I can find anything.
B
« Reply #8 on: June 10, 2004, 05:54:23 am »
Kamil
In that case you can drag the desired package onto the newly created diagram. Double click there and you are linked.
kamil.svoboda
« Reply #9 on: June 15, 2004, 12:04:40 am »
Sorry but I don't understand how to do it :( When I drop desired package onto newly created diagram nothing happens :( and double click is then nonfunctional.
Kamil
« Reply #10 on: June 15, 2004, 10:30:14 am »
Try the following: Create two arbitrary diagrams. Open one of them. Drag the second from the explorer onto the open other diagram. You will be asked whether to create a diagram frame,  reference or hyper link. Select the first option. Then repeat with the two others. You'll see the difference now. Double clicking each of the copies will bring you to the referenced diagram.
kamil.svoboda
« Reply #11 on: June 15, 2004, 10:58:54 pm »
It works between two diagrams, but not between diagram and package. :( I want to create link from child sequence diagram of arbitrary use case diagram to Sequence model (package). I want  to link all sequence diagrams into the one package.
/Sequence model
/Use Case model
    /use case diagram
               +  child sequence diagram
« Reply #12 on: June 16, 2004, 06:48:35 am »
Where is the difference? Drag the desired package onto the diagram. Double click and the top most diagram in that package will open. You may link the different diagrams in the way I showed above. Thus you're enabled to navigate through all diagrams.
Otherwise I can't see what you mean  ???
kamil.svoboda
« Reply #13 on: June 22, 2004, 06:28:58 am »
doesn't work :(
when I drag package onto the diagram in Project view - nothing happens.
when I drag package onto the opened (child sequence) diagram (in main view) it is added as a package element :(
/Sequence diagrams
/Use Case diagrams
    MyFirstUseCaseDiagram
    MyUseCase
           MyChildSequenceDiagram
« Reply #14 on: June 22, 2004, 08:51:36 am »
Just to confirm: you drag the package onto the open diagram window - not onto the diagram icon in the browser? If yes: what release do you use?
