Author Topic: Generating Code to existing file  (Read 2501 times)
StefanR
« on: June 24, 2004, 06:47:10 am »
If I generate a class more than once to the same Delphi-code file, strange things happen:
Each method declaration is preceeded by a notes-header which normally only appears in the implementation section.
Secondly, the notes-header for my class is duplicated each time I re-generated the class. It seems as if the recognition-algorithm doesn't work correct... Maybe this is because I have manually edited headers? They look like this:
// Method:         %className%.%opName%
// Author:         %classAuthor%
// Date:           %eaDateTime%
// Description:
%DELPHI_COMMENT(genOptWrapComment)%
// =============================================================================\n
Any idea?
Btw, is it possible to insert a blank beween the "//" and the comment text for the comments which are written by the macro DELPHI_COMMENT?
Stefan.
