Author Topic: Code Generation  (Read 3741 times)
RickLaird
Code Generation
« on: April 14, 2004, 10:12:00 am »
I testing the code generation mechanism in EA and have a question.
When I make a change to an operation's signature why does EA not update the operation I have changed?  What I see is that EA generates a new operation in the source code instead of updating the one I have changed.  And if I delete an operation in the model and then go through code generation why is the deletion of the operation in reflected in the code?  It means I have to go and manually clean out the code.  If I do not clean out the code and do a Synchronize Model the old operation is now back in the model.
Can someone help me better understand the process of Code generation in EA.
Rick Laird
sargasso
Re: Code Generation
« Reply #1 on: April 14, 2004, 03:49:39 pm »
Rick,
Think of it this way - EA is primarily a modelling tool not a code generator.
Because of its great support for reverse engineering it treats the code as the truth and will only update it if you force it to do so - by setting the "overwrite existing source" flag in the forward engineering options.
Of course this means that any procedural code in the source file will be clobbered.
Bruce
Barry_Pearce
Re: Code Generation
« Reply #2 on: June 24, 2004, 04:33:00 pm »
This is an interesting point.
Personally I only advocate forwards engineering and therefore the model is the truth - the code is merely the model + embellishments (known in the trade as code-that does-stuff).
Maybe we need a option to change the view point ;)
Christiaan
Re: Code Generation
« Reply #3 on: June 28, 2004, 09:21:24 am »
There are a lot of feature requests regarding code generation (inlcluding mine;) and hopefully sparx will implement them. Thinking EA is primarily a modeling tool and not a code generator does not solve much of your problems as a software engineer. If you want to be a productive modelliing tool in the software development process, code synchronization is a must.
regards,
Christiaan
