Author Topic: Remove C in generated Classes  (Read 3027 times)
Andreas_G
  • And that's the way the cookie crumbles.
« on: July 05, 2004, 01:52:05 am »
Hi out there,
at the moment I have the problem that all my Classes have the prefix "C" (e.g.: CMyClass).
But as our coding style guide says this C should be removed in the filenames (e.g.: MyClass.h and MyClass.cpp). (Like you can see, we use C++).
I know that I set the filename by myself if I generate only one class, or each class after an other.
However - I want to generate a whole package.
Is there a possibility to say anywhere "Remove 'C' in Filenames"? I know, rose had this possibility.  ;)
bye
Andreas
AdamHearn
Re: Remove C in generated Classes
« Reply #1 on: July 05, 2004, 05:36:57 am »
We also have the same request!
