Author Topic: Export Tag Values and Links to CSV  (Read 3596 times)
Clare_Francis
« on: July 07, 2004, 08:40:39 am »
I'm trying to export a list of objects (static data) with associated Tag values and links into CSV.  I've tried to set up a File Specification to do this, but can't work out how to add Tags and links to other objects into the list of Available Element Fields.
Can anyone help? ???
barny451
Re: Export Tag Values and Links to CSV
« Reply #1 on: July 09, 2004, 01:35:44 am »
I don't think you can export relationships in CSV; you will have to use the automation interface, which could also export the tags.
Ian
« Reply #2 on: July 09, 2004, 03:38:14 am »
You can go to the database directly. Tags are stored in several tables. E.g. t_connectortags holds tags stored with associations.
