Author Topic: Version 4.00 - Build 729 Released  (Read 20472 times)
sparks
« on: May 30, 2004, 05:38:32 pm »
Release Notes for EA 4.00 Build 729
Added support for moving self-associations around all edges of an element.
Fixed problem with version control which caused problems with Visual Source Safe when user and password were of a specific type
Fixed issue with reverse engineering source code when using a MySQL repository
Fixed bug when importing java source directory into SQL Server repository and Author greater than 255 chars.
Fixed various reverse engineering bugs involving comments in unusual positions.
Fixed bug where new a new class synched into a file sometimes didn't get all its members.
Fixed error when exporting stereotype reference data from a model file with replication enabled into one without replication enabled
Fixed spurious error reported when upgrading model from 3.6 to 4.0 format (error introduced in build 728 - model was upgraded OK depite error reported).
Corrected issue with Port and Part instances when displaying Attribute dialog
Code Template Updates:
 - Delphi Operation templates to allow for multiple constructors
 - Delphi Parameter template to fix default value
